OK, so if anyone has followed this, you kow where I am with this head situation... For those that dont, here's the short version...........
Doing a build, all forged internals, ballanced, B'Pd all that great stuff... Started working on the head, oh noes! A crack... Tried to fix crack, but just chased it deeper... End result, head is a paper weight... My buddy Mark sets me up with an old head... THANKS MARK! Get it in, clean it up, pressure test it, everything is great... Get a call today from machinist: problem...
Ok, now you know the history, here is the problem...
Head has already been decked/machined before... If they do it again, it'll take it below "spec", whatever "spec" is... Frank, my machinist, is concerned it will "GREATLY increase compression"... But im using a 2mm mhg... "Whats the stock hg thickness?" I dunno?
Anyway, I told him to just do it... I gotta get it done one way or another... Just take off as little as possible, but its gotta be perfect...
So hith havein 9.5:1 Wiseco pistons, a 2mm mhg and a head that is below "spec" what kind of true compression will I have? What will it do to my power and performance? Less boost, more power? I dunno... I figure, they boost these 350Zs and make 150+ additional hp from 7psi... Am I making a mistake? Should I just hunt down another head?
Thanks...
Jake
Thanks...
Jake
