i was hoping the milky crap would stop coming up but it seems to show it self every time i let the engine warm up. there is no sighns of water in the oil or on the dip stick, no oil in the coolent.
i just did a block test to see if there is exhaust gasses in the coolent system and it came up negitive, (stayed blue) and i tested for over 5 min to make sure.
should i do a compression test next? if it was loosing compression would'nt the block test have showed it?
i was thinking it might be a very small leak in the oil cooler.
