Might be outta the game. Is there near Hagerstown MD that know supra's?
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
I'm ready to get out of the game. After 4 mechanics destroying my project, I'm at the point of either finding someone local who knows these cars to work on mine, or getting out completely.
I have a 2 bay garage with plenty of tools and 10's of thousands of dollars in parts. I even have a fully built 7M that should be capable of holding upwards of 1000hp. Problem is, I lose the garage in about a month, and I just can't finish this project on my own.
The car does not have a drivetrain installed right now and I do not wish to have it towed anywhere. I'd prefer someone to work on it with me in my own garage, but that has been difficult to find.
The truly sad part is with the economy the way it is, I feel I will take a huge huge huge loss on everything. I mean, who will pay $5000+ for a fully built 7M? And that's without a turbo and injectors. Probably nobody considering a 2JZ can be had for half that. And I have over $10,000 of parts and machining work in the engine alone.
I've been aquiring parts for almost 7 years now. I have so much stuff just laying around. I'd just hate to just lose it all without ever have even gotten a chance to drive the vehicle.
Any help someone can give me is greatly appreciated.
FernandoDLT
357
Texas
"Never give up! Never Surrender!"
-Tim Allen, Galaxy Quest
There has to be someone local who can help you out. Is there a local group you could join? I know the locals here have helped me out plenty. GL!
Fernando
cruisnhard
SM Member
Sep 27, 2007
236
Waupun, Wisconsin
I am in frederick. I am working on an sr20det swap right now and will be willing to help if work permits. (I am in the military.) Depending on what needs to be done and when you can work on it also. I am all about helping others. Let me know whats up.
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
i am having a hard time selling my built 7m that i have $10,000 in parts and machining and a 60-1 turbo with the motor and im only askin $4,000. hopefully someone can help you finish up.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
I've been pushing this project along forever. I just leave my stuff with idiots and now I have to clean up their mess. The sad thing is, I'm on my fourth engine now, out maybe $5000 in labor and other little things (like gasket kits and what not) and my vehicle is in much worse shape then it ever was when I got it 7 years ago.
The vehicle itself is my main worry. It's been left outside for several years by several idiots who lied to my saying they were actually working on it (sued one of the guys and actually won, but I've had no luck collecting in the last 2 years :3d_frown:)
The body was primered by the last idiot, but it's the worst primer job I've ever seen. I never even told him to do it. He primered over the needed body work that he never did along with the tires, weather stripping, etc. What an ass! He did I really crappy job soundening the undercarriage and engine bay. I did the best I could to tighty it up.
He scratched up my new suspension while installing it and now I have surface rust on shocks with 0 miles of use. It freakin pisses me off.
The good news is the body has only 74k on it. Too bad it was neglected for so long. I've managed to clean up the car a good bit. The engine bay has been completely prepped and is ready to have the engine dropped in. There are some issues a friend made me aware of the other night. The ABS controller in the engine bay was removed years ago and the lines have been left open since. I was told there's a good chance that there is moisture in the lines and they may be no good. I'm not sure how much truth there is to this, but he may be right. Also, the hose that comes out from the firewall that connects to the heater core has been crimped shut. I was told I'd have to pull the dash to replace it since it would be near impossible to round the hose off again to the point where it wouldn't leak.
The engine is sound. It only has 3k mi on it and I have recently went over it to make sure everything was fine. It's been sitting for quite some time, but there is no rust in it. I recently pulled the oil pan and valve covers and sloshed some oil around just to make sure it stays that way. The engine has been bolted to a engine stand and is waiting installation.
As of now, the only thing installed in the car (other than a horrific ox blood interior) is the suspension.
My part list:
Engine: 7MGTE (all balanced and blueprinted)
HEAD:
FULLY REBUILD
FULLY CRAZY PORTED ($3,500)
NEW VALVES & SEALS
NEW RETAINERS
MODDED CAMSHALFS (stock camshalfs were rewelded and grind with a bigger cut to push the valves farther)
AEM ADJUSTABLE CAM PULLEYS (BLUE)
BLOCK:
J/E PISTONS .40 OVER 8.4.1
J/E PISTON RINGS
CROWER BILLET CONNECTING RODS WITH CROWER BOLTS
CLEVITE 77 MAIN AND ROD BEARING & THRUST WASHERS BEARINGS
FULLY POLISHED & BALANCED CRANK
PISTON POLISHING
NEW TOYOTA MAIN CAP BOLTS
ARP HEAD STUDS @ 95LBS
HKS 2.0 STOPPER METAL HEAD GASKET
MACHINE DECKED BLOCK
EVERY NEW GASKET & OIL SEALS REPLACED
NEW TIMING BELT
Flandaza Lighten flywheel
Modded New toyota Oil pump
NEW OEM TOYOTA WATER PUMP
NEW OIL SQUIRTERS
MSD 8.8MM Wires
Denso Iridium Spark Plugs
Converted 1JZ FFIM
Turbonetics "Bolt On" (with spacer) 62mm Turbo
(also have smaller Supra Sport Stage 3 60-1 Turbo
Blitz SUS Intake
Turbonetics RFL BOV
Largest B&M oil cooler available with thermostat and braided lines
Cooling:
Fluidyne Radiator
Dual FAL electric Fans
Giant Greddy Intercooler Core (still needs end tanks)
Tranny:
Auto to Manual Swap
R154 Turbo Tranny
Spec Stage 3 Clutch
BEECH Short Shifter
Fuel Delivery:
Rebuilt and Flow-Tested Nippon Denso 550cc Low Impedance Injectors DENSO 285lph Fuel Pump
Aeromotive AFPR w/ braided lines
Exhaust:
Becauseican Custom 3” Mandrel-Bent Turbo Elbow Divorce Downpipe with SS Flex Section, WB O2 Bung, and Ceramic Coating
Becauseican High Flow Test Pipe w/ High-Temp Coating
RSR GTII 80mm Inlet Muffler
Suspension:
Eibach Pro-Line Springs
Tokico Illumia II Adjustable Struts
HKS TEMS Controller
Gauges:
AutoMeter Carbon Fiber Faced EGT/ Pyrometer Gauge
Lotek 2 Gauge A-Pillar
Electronics:
VPC w/ plug and play harness
Apexi Black Limited Edition S-AFC2 Fuel Computer
Stereo:
Radio- Eclipse 5303r CD Player
Front Speakers- Orion HCCA 6S Components
Equilizer- Orion Concept 92.1 Dual 30 Band EQ
Subwoofers- Oz Audio Matrix 10ME’s
Front Amp- Harman Kardon TC600
Sub Amp- Audio Art 100HC
Sub Box: 3/4 Fiberglass (replaces spare tire, drops flush)
8 Gallons of Second Skin Spectrum Sound Deadener
Interior:
Black front leather seats
Custom black w/ suede center rear seats
That's about all I can think of off the top of my head. There's some pretty nice stuff I've collected over the years. It'd be great to get it all up and running.
Below are some various pics.
aye mate
Hiatus over.
Maryland
I can also help, I live in New Market. I'm in the middle of rebuilding a 7M myself. Your name isn't Cory is it?
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
It appears you have the makings of one very nice Supra!!!!!!! Or, the fuel for a lucrative part out, with the convenience of not having to pull anything. I personally would love to see it get completed. Certainly if I can build my car by myself from a parted out shell with my limited knowledge, you can do it too. Help or not, dedicate yourself to making this happen. You CAN do it if you put your mind to it. All the help you need is right here on this site. I'm living proof. Before my Supra, I had changed some oil and spark plugs, and a failed attempt at swapping the carburetor on my old 67 mustang.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
No, my name isn't Cory. Lol.
He did give me a hand helicoiling the exhaust side of my head tho. The last time I saw him he was running the piss outta that purple supra of his. It's got a blown head and a leaky intercooler. Pretty sure he's just running that thing into the ground.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
Much appreciation goes out to all the helpful (and hopeful) responses. As of this point, completing the vehicle may not be an option since time is of the essense. What I need is for some people to come down and assess the situation. See how far along the project is and what needs to be done to at least get the vehicle running. For all I know, it's just not worth it anymore. I have no desire to dump any more money into this vehicle (and it still will need plenty) until I'm presented with a definitive plan of attack with a running vehicle as the outcome.
Anyone offering their assitance, please PM me your contact info. I'd like to get started as soon as possible.
Thank you all.
