Unfortunately, I didn't grab a picture of the mercedes bumper support when I had the chance, but it looks very close in width and overall dimension to the oem bumper support, and weighs about half as much!
Parts arrived:
- new exhaust gaskets for when the driftmotion upgraded ct12as go on
- new 5mm longer bolts for the (5mm deeper than normal) bellhousing-to-transmission holes
- new valve cover bolts / spare set of spark plug galley bolts since I lost a couple from the last set
- new crankshaft bolt (since we heated the existing one a little bit in order to break it loose, and may have weakened it)
- new toyota driveshaft bolts/lock washers/nuts (on the way still)
- upper and lower heat shielding gaskets for intake manifold
- replacement silicone vacuum hoses since I have a couple cracked ones
- toyota oil filter
- new pcv valve
When I was searching for someone that made the size bolt I needed for the bellhousing-to-transmission holes, I came across these lightweight aircraft aluminum bolts and figured why not? It's about a half ounce off the static weight of the car, and they have these nice logos that no one will ever see. :icon_razz
Last but not least, I bought a pair of little peltier dehumidifiers to help combat the moisture in the garage.
These:
http://www.amazon.com/dp/B00RZVHB7M
Parts arrived:
- toyota oil filter
- new pcv valve
These:
