A long time ago I started this thread, and it had some pictures of my dads new (at the time) garage floor, and of a junkyard 1uz-fe I picked up which mysteriously had a hole through part of the block. There were pictures of the chevy colorado AR5 trans, and there were pictures of the body I was previously working on restoring.
Then, I decided instead to buy a rust free car and skip right to the fun part: modding!
In 2012 I bought a nice running twin-ct26 1uz supra from viper92086 (Bryan.) I removed the engine (which was a bad ass swap) to sell to a friend. The turbo setup last I knew found its way into an SC400, and the engine got swapped into my friends ra24 celica. It already had coilovers, whiteline sway bars, and a battery relocation to the trunk.
The following has since gone into the car:
- 2005 Chevy Colorado 2WD AR5 transmission
- JZ to R154 bellhousing
- Spec twin clutch with GM 26-spline input shaft spline for my trans
- Custom 3" aluminum driveshaft from driftmotion
- JZX90 1jz-gte with sump from a soarer 2JZ-GE
- Thermostat-controlled oil cooler
- auxillary engine oil pump for priming the oil system (pressurizes before startup like an accusump)
- Lightweight pulley set
- New starter
- 2JZ (no hydro fan) water pump
- 3" DM stock twin downpipe
- Fluidampr crank pulley
- Traction control deletion
- chrome Stern ST-7 rims 18x8.5", 18x9.5"
- aeromotive FPR
Still to come:
- [IN PROGRESS] highly customized water to air intercooler setup
- Doward cobra big brake kit (bought not installed)
- Suspension overhaul with new RK subframe bushings / beech arms / etc
- Driftmotion upgraded CT-12As [on their way]
- MS3X [not purchased yet]
- built engine?
It ran and moved here: http://www.supramania.com/forums/sh...build-thread&p=2036173&viewfull=1#post2036173
Since then it is idling properly and has driven a little bit more, but still without IC piping.
- New starter
- aeromotive FPR
Still to come:
- built engine?
