Mid-range Torque Wrench
iwannadie
981
gilbert, az
bigaaron said:
The Craftsman torque wrenches with the little number window work well, but be carefull not to twist the handle while using it. It will throw the reading off and they will not warranty it.
A friend had that style I Really didnt like it! The handle would turn all the time on me. I have the style that the whole handle twists to set the torque then you can lock it. Seems to work much better that way and its cheaper.
Also, anyone know how/where to get a wrench calibrated? Ive had mine a few years now and I know people say to get them calibrated after a few years of normal use?
craftsman is fine...
I own a ton of stanley tools and they're as good as craftsman in most ways, but far cheaper...
even have a lifetime warranty, but it's not as easy as walking into a sears and getting a new one like craftsman...
snap-on is a ripoff on most of their tools as well...
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
X2 . . .
I swore to never buy another Craftsman torque wrench when they screwed me on a $100 digitorque wrench. The handle came loose on about a year after I purchased it - same problem that bigaaron mentioned(90 day warranty was all it had). You've got to watch what you buy Craftsman. Wrenches and sockets are usually lifetime warranty, but some of the tools have a limited warranty and or aren't made in the USA. Snap On torque wrenches only for me now. If you're on a budget, check the pawn shops for torque wrenches. You can usually pick up a nice Snap On for less than half of new price.
supra_ed said:
craftsman DO NOT WARRANTY TORQUE WRENCHES. i found that out the hard way
mkIIIman089
Ohio
Snap-on is the best, but if you looked at their prices you would think they were at least 2x as good as the next competitor. Which just isn't the case.
exactly, my cheap ass stanley tools are NICE, the ratchet is like the craftsman pro line as well...
I got the craftsman torque wrenches where you twist the handle to the torque setting and can lock it. Never had an issue yet...
If money was no object, sure I'd have snap-on tools, but it's just not that cost effective to me...
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
If one buys a used torque wrench, they should look into getting it calibrated prior to buying it. Factor that into the cost.
My craftsman wrenches are accurate as tested by the maintenace department at one of my old jobs. It was tested at a low, middle, and high value. All 3 were within a few pounds of indicated. This was both the 1/2 drive and the 3/8 drive model.
