MHG Question
oldsking
789
Chapel Hill, NC
I was searching and think I got it nailed down but I am still a bit stuck. I am leaning toward composite because of cost and ease but I want to run more boost then stock level so I know I need a MHG. Back when I built domestics we could run Fel-Pro's and tons of Spray and be fine with ARP's but these 7m's, ugh..
Anyways, the block and head i have are resurfaced but not decked though they are super smooth. Could I run a MHG of a small size? Concern I have is the cam gear cover where it bolts to the block? The thicker the gasket the lower the compression ratio correct?
gaboonviper85
3,236
Northeast Philly
Generally the thicker the gasket the lower the compression, yes...but it all depends if the motor was decked at some point in it's life...sometimes a thicker gasket will make stock compression if done properly.
Keep in mind that a 100 shot of nitrous in a 3l motor is different than a 100 shot in a big v8....same amount of spray for both but one breaths much more air and can handle alot more...
I don't understand your concern about the timing cover is....your only worry should be that the timing cover is perfectly flush with the block deck!
oldsking
789
Chapel Hill, NC
I was thinking that it bolts to the block also sorry haha
Okay well If I want to lower the compression Id go with a 2.0m because when our head is compressed and torqued its 1.37m so technically I would have slighty lower compression going this route. My head and block were not decked as the paper work shows (I bought this set up from a buddy before I moved) but they were resurfaced and both are perfectly smooth. I think it would be wise to run lower compression for more boost in the future right?
Apr 10, 2008
322
South East USA
I went to a 2.5 mm cometic and blueprinted the compression to 8.2:1
Tried a few composites but they don't hold up.
Everything that learned worked on domestics is out the window with this engine.
Smooth and FLAT...smooth and flat
