I was searching and think I got it nailed down but I am still a bit stuck. I am leaning toward composite because of cost and ease but I want to run more boost then stock level so I know I need a MHG. Back when I built domestics we could run Fel-Pro's and tons of Spray and be fine with ARP's but these 7m's, ugh..
Anyways, the block and head i have are resurfaced but not decked though they are super smooth. Could I run a MHG of a small size? Concern I have is the cam gear cover where it bolts to the block? The thicker the gasket the lower the compression ratio correct?
