Best bang for your buck. I don't have a standalone, so I am not going to run it yet. You can run upwards of 23-26 psi on pump. So yeah, you will see great gains.
usually you use the inj to run higher boost on pump gas. it does work, but has consequences. be sure the system is maintained and setup correctly or you could detonate the motor.
