meth injected ct26? Good boost past 13.5psi?
turbo87targa
482
colorado springs
so. Who thinks this sounds like a potentially good upgade WITHOUT upgrading turbo or injectors? To have a ct26 meth injected at 13.5psi to cool the hotter air. You may be able to pull around 18psi of good cold air without any major money like bigger turbos.
I've been talking to hottecennessy about meth injection for the t66 setup I'm building and this idea of a ct26 meth injected came to mind as something I should share. See if anyone else thinks it would be worth it.
It also helps for future upgrades when u do get a bigger turbo and injectors you already have the extra hp of the meth.
What do u smarter guys think?
(please tell me I had a good idea and it wouldn't just blow up LOL)
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
meth helps. but its like gas, you faster you go, the more you use.
if your super strict about keeping track of your meth, then your good, but i know people like IJ have done it where he puts a sensor in the bottles so once it goes below a certain point it doesnt let him boost past 3 or 5 psi...
if your determined to squeeze every HP out of the ct-26... go for it, but i dont like having meth on a street car.
turbo87targa
482
colorado springs
well I'm planning to run meth with a t66 on my street car, I just posted asking about the ct to give those looking for ways to pull the most out of the ct26 a different angle to look at. I'll have mine controlled by stinger so it should work fine as long as I check the resevoir often. I'm also getting a 4 quart tank to make sure I pack enough ;)
flatblack
maple ridge bc
Meth injection has done nothing but good to my brother 300zx tt. He used to detonate at times at 16 pounds on bigger ball bearting turbo's, now he can run 24 psi with no sign of detonation, didnt change driveability what so ever. Hes using the snow performance kit, but apparently the aem ones are a bit better. His quarter mile went from 12.9 at 111mph to 12.3 at 118mph on street tires.
