Enraged your a GENIUS!!!! i think gutting the stocker and piping a ford on there is a perfect simple way around using the toyota 6 wire, a ford is the way to go thank you!
			Pyro15D;1902474 said:The power is supplied via megasquirt. Megasquirt can drive a bipolar stepper motor IAC, but not a unipolar IAC. The way the stock ECU drove it was with by grounding each coil like you said. That is the unipolar way of driving it. That's why it needed the 12v power. Megasquirt supplies the power directly and switches polarity to the coils to actuate the valve. I did a test with it and cycled it all the way through its 125 steps from open to closed and back again. Speedfreak426 did the same thing on his 1977 celica with a 7m swap. It works. I'm just trying to save you guys unnecessary time and money.
mkiiichip;1904539 said:Today I got it working with a stimulator, and MS3+MS3X. I can get it to move to any position between 1 and 230 steeps, it runs to the home position at power on, reacts to coolant based idle up, moves to a cranking postion.
DustinS;1935072 said:Any info you can give on how you got it working?
figgie;1935223 said:here you guys go
http://www.supramania.com/forums/sh...ta-IAC-and-stepper-design-)&highlight=bipolar
can't believe I did that work nearly 7 years ago already. Back then, this was based on Tec3 but works with any EMS that supports bipolar (which is most) stepper control.
the important part will be the .25 seconds per step rate. To fast, fry coils, to slow, won't move.
mkiiichip;1935292 said:I am a little reluctant to share to much of my setup at this point because it is totally untested at this time. I will say that all the mods inside the box are per the manual.
Hmmm, when i was doing my testing i found that the valve would not move with a signal any faster than 5ms between steps. It seemed to work great at 10-15ms. I Kept moving the valve at these settings for several mins without the valve generating any noticeable heat.
At .25 seconds per step on a valve that has 200+ steps, it would take almost a minute to open or close the valve. Did you mean 25ms?
EDIT: then again I did not swich the configuration of the valve. I may be comparing apples to oarnges.
