oooh, megasquirt discussion
i just got done installing ms2 (3.0.3t with some mods in the code) on my mark4. Zeal engineering dual VR board for the crank/cam input (dual wheel 12 crank teeth, 1 cam tooth). using fields patch harness. sharing coolant temp sensor, and i put an open element gm iat into the throttle body.
it's just controlling fuel for now, leaving the ignition to the stock ecu, which works out awesomely.
i'm using table switching, so there's 2 fuel tables (below 110 kpa, and above 120 kpa), switch happens at 115 kpa, so the resolution is 16x32 cells. tuning is done via tunerstudio's live ve analyzer, which works exceptionally well. lc-1 is putting out 10-16 afr range across 0-5volts analog output.
i have ignition working also, but when i actually hooked it up and threw a timing light on it, it was wandering around between idle at 3-4 grand, so i'll have to look into that some more (maybe switch to NE2 for cam VR, as that should reduce the offset angle for dual wheel)
this is 2nd car i have running on megasquirt, the other one is a se-r specv with 57 trim t3/t4 on a built qr25de boosting about 20 psi. the sentra has a megasquirt3 daughterboard, which is quite awesome.
all the boards are v3.0.
