Hey, I am installing ms2extra on my 7mgte and everything works apart from the cps. I have yet to install it, but I bench tested it using a drill and it loses sync below 500 rpms. Now you may think that it isn't that big of a deal except its too low to even start the engine. Now, the clearance between the rotor and the vr sensor is pretty much nonexistent. It's just far enough to not be touching the rotor. Anyway, what can I do to help with low rpm sensitivity?
