Maxing out the Lex AFM
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Well as i just learned the other day, you can max out your lex AFM's. I took special notice to it today knowing i had a persistant acceleration problem still but seemed to be reading ok.
Via SAFCII i monitored it as it climbed past 1350Hz at only 11-12PSI or so. Someone mentioned there's topped out at about 1500Hz. So now what? I'm reaching my limit soon enough on the stock turbo! I wanted to at least go 57trim sometime soon but i guess not. Is there a way to get around this w/o spending 200+ on Maft or MaftPro to replace the AFM, i mean i already have SAFCII as a feul tuning device?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
When you max things out you will get fuel cut. Don't worry about the Hz. I have a stock AFM and have seen over 1700Hz at around 11 psi.
Just keep an eye on your AFR.
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Can I ask a quick question... and it may seem dumb.
What model Lexus AFM do the 7mgte's take? Or what model car do I need to hunt down in a parking lot?
Basically where do I get a Lexus AFM for the 7mgte???
Appreciate it.
TurboWarrior
Canada
Are you hitting fuel cut or is that just an observation? If the signal maxes out i think it just dumps maximum fuel does it not? It doesn't mean you're stuck at 12 psi.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Appreciate it.
You need the AFM body, your electronics will drop in.
1990 - 1994(early) LS400
1990 - 1994(early) GS400
22250-50010
22250-50011
22250-50030
22250-50031
Those are the part numbers of the afm's that will work
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Bigdough666 said:
Im at 20psi on a Lex AFM with almost no tune at all. Somethings wrong if youre hittin fuel cut at 11-12psi. Check for boost leaks.
no boost leaks, happens in all RPM. sparks new, wires new, coils good igniter good, AFM good, only leaves the new RC550 injectors.
