f00g00;2088650 said:
Don't forget the valve clearances. Toyota uses shims in buckets, there are no adjusting these except by putting a different shim thickness in. They can be a pita to mess with so make sure the machine shop has experience on this. If you do it yourself you will need a micrometer and a tool to remove the shims. And try not to mix them up.
Good advice is only good if you USE it. Lesson learned.
I guess I thought the machine shop was going to check the valve clearances, but since they thought the camshafts were junk and did not re-install them, I guess they never got around to it. I should have realized this and checked the clearances myself before putting the head back on, but that's what happens when you are anxious to get your car back on the road.
I have no idea if incorrect valve clearances would cause the idle problem I have or not, but I figured it couldn't hurt to check them anyway. I've got it back apart and sure enough 12 of the valves were out of spec. I was able to move a couple of them around, but ended up ordering 7 new shims. I'm just waiting on them to come in.
By the way; for anyone else changing shims, you may see some posts out there that say you can just use a couple of screw drivers to push down the valve and pop out the shim. This is near impossible to do unless you're Hurcules with 4 arms. You will either need the special shim removal tools or do like I did and just take the camshafts out. It's really not that much more work to take them out and then taking the shims out is a breeze.
In regards to my "hot start" issue. I did take off the fuel pressure vsv and tested it per the TSRM. It passed the electrical test, but when I tried blowing air through it, it seemed like it wasn't flowing freely. I thought maybe I could clean it out with some brake cleaner. Bad idea, that made it even worse and now no air will pass through. Naturally this is a discontinued part so I took the advice of another thread and will be using Dorman part 911-604 to replace it. I will have to see if that fixes the hot start issue.
