on your turbos i notice alot of stage II and stage III next to them? is this just for generation identification or is there differances in turbochargers. also any updates on your ball bearing line up?
88supraTT;1055285 said:on your turbos i notice alot of stage II and stage III next to them? is this just for generation identification or is there differances in turbochargers. also any updates on your ball bearing line up?
Jimmysmk3;1055470 said:i am currently running the t70 with a .68 housing and its working great for me. i see 19lbs just over 4000 with a vpc. i know mk3brent also had the t66 and i beleive spool was even quicker for him, maybe he'll chime in.
my question is are you going to be getting anything ball bearing?
SupraOfDoom;1055553 said:What is your most comparable turbo to Garrets GT4088R? Looking for something along those lines, dual ball bearing quick spool that makes good power.
THX.
supra8795;1056026 said:Ive been running a t70 for about 3 years now and i love it. Ive made 551hp with this turbo on pump gas. I should be in the 600 range with race fuel. It is pretty laggy on a intercooler setup like stock but once you go with a front facing intake manifold lke i did you will see extremely fast spool times.
FullNelson;1056162 said:Im guessing that was a .68 trim, did you notice the power drop off in the higher RPM when driving? i was looking at some dyno maps and they seem to peak quick and start dying off quick at about 5000
DonS1mpson;1056042 said:Do you have a rough idea how much extra it would cost to get a T-70 shipped to England?
supra8795;1056382 said:Nope not at all. I have 272 cams so my power keeps going all the way to the revlimiter. If i could get rid of that it would continue to pull till i let off the gas. Ive been running 25psi for awhile now and sometimes ill go to 30 with no problems.
