MAP ECU's were to buy
veedubin
Official SM Decals
As stated i am interested in removing the restrictive AFM, in favor of a GM MAP sensor. also so i can run a BOV...... i love that sound it's almost orgasmic. :love: :icon_bigg Yea it's kinda a stupid reason to change over, so sue me. any ways i heard that something as simple as SAFC will allow this to happen at least with the BOV but i really due want to rid the car of the afm. so any suggestions???
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
2543arvin said:
You dont need a map sensor to run an aftermarket BOV. Have you even searched this site????:3d_frown:
you dont but it will help especially if its and atmo vent which if im understanding his post correctly he wants to do.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
map ecus get rid of the AFM all together, not put in a GM maf. and to the origional question, i would go through powerhouseracing or titan. powerhouse also has the PnP harness for the map, and then all you need to do is run a vac line from the intake mani to the map ecu. i used a PnP harness on a MKIV and it was cakewalk, once we got the vac line into the interior.
csolstad
33
Clinton, NJ
why not just go maft-pro, everyone seems to like that better
edit: i run a ssqv and vent it to the atmosphere on a stock ecu/afm.. no problems whatsoever
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
I love my maf-t pro. I was waiting to hook it up to fix a prob. I was having hitting cut at 5k rpm's It started getting really bad this weekend so I desided I would hook it up an bam prob. solved. also solved my idle on hot restart prob.
I have not updated and the only prob. I am having is a very slight rpm drop when I hit the gas.
My mk4 has a map-ecu on it though i have not driven the car yet so i can't tell you much about it.
veedubin
Official SM Decals
Well I jsut checked titan, no go on the ecu's i didn't see any. aslo I should have mentioned that my car is an 87 turbo 5 speed and power house racing only carries for 89+........... so am i screwed or what????
veedubin
Official SM Decals
F_T_F said:
it will work in a pre 87 you might just have wire it your self or pay someone else to do it.
Well wiring is not a problem, I'm a mechanic for a living and ASE in the electronics section :naughty: i'm just lazy and a PnP harness would be very helpful. also who can verify that a map ecu will work on the pre 89's any one else got one???
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
the t3d said:
so, what exactly is the easiest, most reliable to get rid of the stock AFM? what if you use a Lexus AFM? any differences?
Easiest and most reliable don't go hand in hand.
Most reliable would be standalone fuel management.
