Make a 2JZ N/A block, into a GTE one?
Satan
Tampa
Getting ready for Houston and wanting to get things started before I leave...
I am going to get an N/A block to replace my TT block. They are inexpensive and plentiful. I'll swap over all of the oil pump and other things atahed to the block and re-use my recently prepped head. If the pistons are different I may swap them in as well.
I looked in all of the Supraforums stickys etc, but still do not have very complete info... and it now seems you can't create a new thread there (today).
_________________________________________________
I would like to drop off at machine shop and have the oil squirters and oil-feed tapped into the block.
Will they know what needs to be done, or will I need to supply with thread pitch and other specific info?
Any other differences that they can address, besides these?
Thanks,
E
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
the blocks are the same. the NA block does not have the oil squirters but they aren't a HUGE deal. a guy on Club NA-T was making 700-800 whp iirc on the stock block.
the pistons are different. they are higher compression, to fix this you eed to either buy TT pistons (or swap them out in your case) or buy a 3mm head gasket to lower the compression and run the NA rods and pistons.
The Reaper
Jan 10, 2006
1,909
Florida
i thought for sure it was a 3mm to make it 8.5:1 comp.
maybe it was 2.5mm which pushed it a little closer to 9.0:1
but yea you get the idea hahaha
thanks scott
Satan
Tampa
Good info...
Gonna be using a single turbo and do not plan on anything over 500HP... more like 400HP daily driver.
What about the oil feed from the side of the TT block... I guess sems easy enough for me to drill/tap.
Will definitely replace the rings and bearings while I am at it. Anything else to be done "while I am there?"
The Reaper
Jan 10, 2006
1,909
Florida
not that i know of.
i have a NA block sitting at Tissimo's house that i am planning on putting TT rods and pistons in it and making a 1.5J myself.
need to pull it apart soon though and look it over, cause it was pulled out of an SC300 that blew a HG and had really low compression. need to make sure there's no crank shaft damamge before i go about putting rods and pistons in it
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
YOu sure about the pistons been different??? I thought they were the same pistons & rods, I thought i read somewhere that the only difference where of course the head & the very thin head gasket they have, The head gasket on the N/A 2j is 0.2, I can be wrong & i misread, Please feel free to correct me.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
They are definitely different pistons, but the same rods. The pistons are made of the same material/process at the GTE(so they're strong); that may be along the lines of what you read.
csnow
Matthew 6:33
Palm Bay, FL
Satan;957847 said:
Good info...
Go over to clubna-t.com There are a ton of threads on this very topic. Most people use the IS300 union bolt with the GE oil filter housing for the oil supply. Use your GTE pan since it has the return. There is no need to tap the block for the oil supply.
Chris
The Reaper
Jan 10, 2006
1,909
Florida
yes my information was spot on minust the fact about the HG which Scott pointed out. it was close but i haven't read about it in a while.
i think i might be getting the NA long block from tissimo here in the next week and go ahead and start tearing it down to see if its worth it to swap blocks.
CSNOW is correct. about 95% of the people use use the union bolt from the IS300 to use for an oil feed line. have to run a longer feed line instead of tapping it just below the exhaust manifold but it does work.
Jostar
May 21, 2007
746
Chicago
Ok, Probably that is it, I know that there is a Sc300 with 900 hp on a stock n/a block & head....
Satan
Tampa
Wow... lots of great info.... headed to that other webiste now.
I figured that I'd swap the internals and everything else I could. I am almost sure that the TT block I have is cracked somewhere. Replace the bearings, piston ring, and any other "worn" components and I should be good-to-go for another 100K.
The Reaper
Jan 10, 2006
1,909
Florida
well good luck Satan......now go back to hell where you belong!!!! sorry been waiting awhile to say that to you.... ;)
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Well, I swapped my 1jz bottom end and am using the 2JZ NA block for the 1.5. Just used the MKIV head gasket as it is definitly 4 layers thicker than the stock NA ( single layer ) gasket.
I did not boither about the oil squirters - going by what I read on ClubNA-t . Currently I am doing 1.5 JZ, but in the future plans I will convert to full 2JZ with everything else being the same.
I am running a sandwich plate between my oil filter housing to supply the oil to the turbos.
Satan
Tampa
Thats funny... from my biggest supplier ;-) :icon_evil
The Reaper
Jan 10, 2006
1,909
Florida
yea i think the stock 2JZGTE HG makes it 9:1
the sandwich plate is a pretty smart idea as well.
how long of an oil feed line do you need to make it reach the turbo?
suprastanger507mgte
Hayward , Ca
Im running stock 1jz twins as a start.
I am cutting off the stock oil feed lines and welding on a fitting on it, somthing that can take a -4 I think. About 3.5 feet of oil feed with a "Y" and two short pieces should be enough.
