found this cached in google... thought i mite bring it back
i've just needed to find this info for someone so someone else may also find it useful again
Original post by Serzy
I just got my MAFT installed and I have regular Autometer EGT & O2 guages and a Digital Voltmeter that can display Hz now I have a few questions and I hope some of you gurus out there can answer for me
My voltmeter can display Hz it has two settings for displaying it High Trig. & Low Trig. whats the difference between the two? Which one would I use to monitor my Vf signals Hz? To monitor the Vf signals Hz with my voltmeter I use the Diagnostic Blocks Vf port for the red probe of my voltmeter and the E1 port for the black probe of the voltmeter... Is that correct?
Now in the MAFT it has options for a 1500hz clamp a 1450hz clamp and an 1400hz clamp? Which one is the safest to run? Or which one will allow me to hit FC sooner? I just want to run like 15psi my stock fuelcut occurs around 13.5 to 14.5psi.
At the moment in the base settings for my MAFT I have
Aux C (1400hz clamp)
Base 2
Idle 0
Mid 1
WOT F
With these settings my autometer AF is always bouncing into the green for cruise and part throttle and when WOT the gues lights up to the third green (I know the narrowband isnt accurate but it shows that im not goin lean) my EGT'S are actually a bit lower than stock and the cars throttle seems much more peppy and boost seems to give more of a snap on effect.
Thanks for any help or insight anyone can provide. And if anyone wants to chime in with any offtopic but relevant information please do!
Base 2
Idle 0
Mid 1
WOT F
