So with all the MAFT-Pros finding their way into Supras these days, how many of you are actually working the VE tables, to get readings for the TCCS?
So far, I'm between 1.25-2.50 Vf at basically any part throttle, under 100kPa (that means no boost) after extensively going over the VE tables. Driveability is exactly as it was, stock.
Once I start to climb into boost, though, my Vf drops to 0.0 (I did this on purpose, as I had to max out the TCCS's ability to adjust the AFR, so I could get it where I wanted), my AFRs drop to ~13.5, down to ~12.8 @ 120kPa (~3 psi), and it falls to 11.6 around 3400rpm and 14psi. Runs like a scalded dog right now
BTW, if you have the TPS Start (for boost control) set too low, a heavy part throttle run will give you a full 14psi, and you WILL hit FC with only ~1000hz. I guess FC really is tied into RPM as well as Frequency! :icon_bigg
