MAft Pro non-technical question
afein
7
Just curious where people are mounting the actual head unit. Of the many things this unit is good at, looks is not one of them.. :) Is this a Glove box only mod? Just curious to see how other people have installed or mounted them?
Thanks for the input.
Scott
SLO-MK3
Not on the 1jz bandwagon
Nov 4, 2006
246
Plumas Lake, CA
Mounted mine in the center console
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
im guessing that he took it out to illustrate the wiring. he probably puts the wiring back in and has the translator in the center console when driving
Adjuster
Was just planning on stuffing it in the radio pocket, but might put it in the glove box, or some variation of that. (Tucked under the right corner of the center console with enough wire loose so it can be brought up and used, then tucked away the rest of the time.)
shaeff
Kurt is FTMFW x2!!!!
10
Around
i just keep mine in the glove box. i left the wires long enough to pull it out and make adjustments from the driver's seat.
-shaeff
afein
7
Thanks for the input, i am planning on using it as a boost controller as well, so having it handy would be nice. Any other set ups beside center console and glove box?
cheers
Scott
