maft pro mounting location
supra90turbo
shaeff is FTMFW!
32
MA, 01440
GrimJack;1676531 said:
Looks like the one from DrTweak...
Ah yes, I just checked out his site. Looks like you are right, sir. I think I'll still tap into the factory harness and save the $130...
arknotts
formerly ark86
Jan 9, 2008
461
Ohio
supra90turbo;1676456 said:
what harness extension is that, arknotts?
Nope, it's an AEM extension harness spliced into by yours truly. :)
Maybe that's the same one DrTweak uses? I've never seen one of his.
---------- Post added at 11:19 AM ---------- Previous post was at 11:15 AM ----------
jdmfreak;1676317 said:
but on a serious note why does everyone put it in their Glove box.... maybe a question i will answer myself once i start messing with it......
It's a good place because you shouldn't need to mess with it constantly once you get the tune dialed in, but within reach if you need to change anything. Plus I run most of my wiring through the stock wiring harness grommet that comes in behind the glovebox.
CPT Furious
Now MAJ FURY!
KDOV
Standby...
This is what I did. I would also argue that it does still act as a gauge. The sensor monitor page allows four visuals. I watch Aux1, intake temp, boost pressure, and load.
The wires pass through the cabin temp place and on to the factory harness.
