Maft Pro Help
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
Ok so i have tried to search on here on the main scale of the maft pro and nothing would come up. I i have to ask for help from the people that know best. I was messing with the main scale on the maft pro and nothing was happening, i checked all the wires everything is right. Is there something that im not doing right?
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
sorry about that. the car is 89+ with wisco pistons powder rods, 720 inj 60-1 turbonetics turbo, hks head gasket with arp's. im running version 4.40
Vehicle Select 00
Number of Cylinders 6
displacement 3.00 Liters
Airflow Source 0X00 Select
Manifold Pressure Source 0X00
Density Comp Source 0X00
Barometer Comp mode 00
Frequancy Out Mode 0X04
V out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 1 Select
Freq in mode 0
Aux 1 Mode 00
Main Scale - 11 (here is the problem, no matter what I input here nothing changes)
Volts OUt 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 2.20
Tune Load Point Low 36.40
Tune Load Piont Mid 100.10
Tune Load Point High 143.00
Freq Out Max 0
Timing Monitor, Base adjust 0.00
Timing Monitor, Correction 1.27
AFR tracking enable delay 1.00 Seconds
FE Smoothing 30
AFR Min TPS 2.40
AFR Min RPM 3008
AFR Min MAP 161.30
AFR Correction Lean Limit 10.00
AFR Correction Rich Limit 18.00
AFR Correction Gain 5.20
AFR Aux % 0.00
TPS Enrichment 1.00
TPS Decay 0.30
throttle Body Size 7
TPS MAP Max 0.00
MAP Enrichment 0.10
Boost Enrichment 1.20
MAP TPS Min 0.80 Volts
MAP RPM Min 1504
MAF Limit TPS Threshold 0.00 Volts
Maf Limit 0.00
Maf Limit/KRPM 0.00 Grams per second
I hope this is everything that you need if you need more please ask.
JimR
Canada
In addition to that, the airflow mode (afm,maf,sd) and re-read the latest manual on fullthrottletech.com
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
when i adjusted the main scale all the way + / - it didn't die out from to lean or to rich. witch from the little i know about tuning should have killed the car. correct me if im wrong.
drjonez
the motor city
www.4cefed.com
drjonez;931757 said:
as always, help is impossible without information-
-year of car
-complete mod list
-MAFT pro software version
-MAFT pro settings
still waiting on this info in addition to ECU codes....you'll never get anywhere unless you attack the problem systematically.
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
read post #4 for car year, mods and maftpro setting and version. the code are 24,31,51 that is when the maftpro is plugged in, now with it unplugged and the afm plugged in i dont get any codes.
drjonez
the motor city
www.4cefed.com
well, if code 51 goes away when you remove the MAFT pro, you have it wired wrong.....likewise w/code 31.
