ok, this isnt in a supra, its in a cressida thats had a swap, using the supras ecu, engine, ect, all that. so basically running the exact same as a mkiii, the car has plenty of mods to it, was running an safc and i wanted the maft pro to eliminate the maf and isc lines, and to be able to get a better tune out of it and remove the fuel cut as well so i can start running race gas.
started the install today, but i have a problem. the car will start, and run, but when revving (havent tried to drive it yet because of the problem), it wont rev past 2500 and will have stutters up until then, like the afm is disconnected, also the CEL is on the whole time since the afm is disconnected.
tried reconnecting the afm, setting the f-in back to 1 where it was originally just to see, and started it back up. and it would rev fine then, still didnt try to drive because this isnt the way its supposed to run and i dont want to fuck up the engine with bad timing possibly.
also, the KS wire it says to tap into, but whats the correct way to hook this up, it might have been done wrong on my side, having connected into it by just tapping in and leaving the wire whole, im thinking it may need to be disconnected and then have the maf connect to the ecu side of the wire since there isnt supposed to be an afm when its all said and done
any help is appreciated as to why its happening like this.
Ian
Ian
