MAF-what is needed to eliminate it.
92nsx
2,957
Clearwater, MN
Maybe my searching sucks but I am going to fire this question out there in hope for your input. What is needed (Electronics, hardware) so I don’t have to use a Mass air flow (MAF) sensor. I hate hitting fuel cut.
92nsx
2,957
Clearwater, MN
Thnks for the quick input. Sorry about maf and afm.
So here is a new question, Will the greedy e manage eliminate the need for the factory AFM, and not hit fuel cut.
I am asking because i used to run the Apex1 SAFC I i still hit fuel cut off and on.
I am Looking for a new Piggy back, that pretty much dosent suck
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Did you read that entire thread I posted? I believe it mentioned the emanage....if not search "greddy emanage" or "eliminating fuel cut". The reason I say this is because Ive not worked with the emanage, so try searching and see what it brings up.
Also, check the piggybacks section in the forum, theres some good info in there.
mkIIIman089
Ohio
I think you need to do a little more research around the FAQ/tech threads on this topic. Even if you swap out the AFM for a MAP setup, fuel cut will be exactly the same.
MKIIINA
Destroyer of Turbos
Plano, TX
if you are asking about elimating the maf you dont need an e-manage. you need to read the faq and then decide what your goals are and then decide if the vpc, maft-pro, or some other option best suits your needs.
92nsx
2,957
Clearwater, MN
Thank you that is what i was looking for. :bowdown: I Appreciate your answer, just what i was looking for "a simple answer".
Now if you would answer this. I dont want to run 2 or 3 differnt computers, just 1 that will do most everything, Will the e-manage work for no more afm, adjust fuel, and othee fun sh**. well hell i can sum it up. will e-manage put the safc to shame and still eliminate the afm?:1zhelp: :1zhelp:
92nsx
2,957
Clearwater, MN
Thank mkIIIman089 and MKIIINA you guys rock, no bs just answers:biggrinbo
Now if any one wants to add there 2 cents feel free, again just looking for a new piggy back that dosent suck like the safc and no more AFM it big tim BONUS. I had no luck with the safc it was like a stripper: looks good ,sounds good but no action and just takes your money :boobs: .
92nsx
2,957
Clearwater, MN
It sound like the MAFT-Pro has tons of add-on's too:love:
Windows interface, boost control.
What else can it do. MAybe make me some toast?
Kylar27
Supra Lover
Oct 2, 2005
184
Connecticut
I was looking into this also. I think i will be going maft-pro
With add ons you can run speed density to get rid of the afm, get rid of the need for an s-afc or other air fuel computer because it can do that also, and it has an option for a electronic boost controller too :love:
The only thing I dont like about it, and yes this is a superficial complaint is that it doesnt have a cool/flashy/graphic screen or display.
bowsercake
828
Irvine, Ca
E-Manage Ultimate will eliminate the AFM but it has not really been tested on the 7M. If you want to eliminate it your best bet is to go with the MAFT-Pro because many people on this forum are using it with success.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i would go for the maftpro with speed density. i just installed mine and im loving it. they sell optional kits for boost control and wideband tracking (which is vital to tuning). it comes with a handheld display or you can directly hook it up to your laptop to make adjustments. and its a whole lot less than most standalones
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
You want MAFT, maft wants you ;P (tung action)
O yeah! what he said /\/\/\/\/\/\/\/\/\/\/\/\
Thats what i want to do.. i think it even comes with boost control
92nsx
2,957
Clearwater, MN
Kylar27 said:
:The only thing I dont like about it, and yes this is a superficial complaint is that it doesnt have a cool/flashy/graphic screen or display.
I second that a better display would be sweet. :evil2: It looks like it out of the 80's of something. :nono:
