maf help
DSGsupra89
http://www.highgearlife.c
Jun 8, 2007
116
West Melbourne Fl
OK I'm thinking of buying a maf translator my friend has the maf pro but thats cost $400 buy itself. But he told me about the maf gen2 works the same as the maf pro but a little differnet. My question is the maf pro you can work with out your stock maf sensor does the maf gen2 do the same I'm trying to run with out the stock maf on my car causing trouble. Or does anybody know the differnts with this maf translator or there any other out there that does work with out the stock maf. thanks
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The MAFT Gen II is a MAF Translator. It allows you to switch from the Karmen Vortex AFM which the GTE uses to a less expensive and better flowing GM MAF.
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
Thanks I'm going to get it but just want to know. Does it uses an boost controller kit like the maf pro I just want to know if it does if not it does not bother me.
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
sorry I'm going to buy it but was woundering can it work with an boost control kit if not its fine. Or can I put a speed density on it or any of the stuff that the maf pro can
CRE
Oct 24, 2005
3,485
Denver, CO
The Gen II is not capable of controlling boost, timing, or converting to speed/density.
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
so i can mostly just use it for fuel controller but well able not to use the stock maf on the car and take it off when when i put the gen 2 on
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
a maf converts a General Motors mass air flow senseor signal into information the stock 7m ecu can understand (you cannot use stock afm you have to use a gm maf). benifits of it are better flowing maf, fuel tuning w/ stock injectors or much larger, cheaper replacement of maf (like 90 bucks as opposed to 190), fuel cut raised it cannot controll boost or timing. but can be used with another boost controller and or timing controll. if you have any other questions feel free to pm me.
-Zac
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
so you saying not only I can't do nothing but fuel control but I have to get an gm maf too. I really just want the stock maf off my car period not put on another I was thinking of getting the maf gen2 look like the maf pro is more wearth it. It takes the stock maf completly off thats my goal thanks man
-Zac
CRE
Oct 24, 2005
3,485
Denver, CO
Ugh.... had I understood the question at the beginning this would all be out and cleared up by now.
So, here's the question: Can the MAFT Gen II be run as an AFC?
Answer: YES!
You do not have to use a GM MAF with the GEN II although I really can't think of a reason not to. The GM MAF's flow MUCH better than the stock AFM. However, if you want to stick with the stock AFM, yes, you can (at least according to the info in their support forum).
BTW, the manual is available here: http://www.fullthrottletech.com/showthread.php?t=1849
Try using more punctuation, make actual sentances and use paragraphs. If you don't know the precise way to phrase a question break it down and use examples... you'll get your answers a lot quicker.
89turbotoy
Jul 30, 2006
309
cincinnati
Answer: YES!
no i think he wants to eliminate the afm alltogether and in that case he needs maft pro w/ speed density. but dgsupra you do need to learn how to ask smart questions.. wait come to think of it i saw a post on that somewhere..oh yeah http://www.supramania.com/forums/showthread.php?t=2016
CRE
Oct 24, 2005
3,485
Denver, CO
You didn't sound like a dick at all. I may have, but I'm getting sick of people writing unintelligible posts and then bumping six minutes later when they don't get an answer quick enough.
I accept the possibility that English may not be this person's native language. However, in that case they should have enough common sense to use grammar (present in every *written* human language on the planet) to attempt a post which is as easy to decipher as possible.
