Ive recently been considering all my options for my 7mgte that i want to put in my supra. Right now i have a block, rods, crank, all the parts etc. These are the operations that need to be done:
- Crank ground
- Undersized bearings
- Block main webbing line bored and matched to the crank and bearings
- Rods re sized to match crank/bearings
- Small end pin bushings inspected/possibly replaced
- Cylinders bored/hones .020" over
- .020" over pistons and rings (~$120)
- Suspect that valve guides need to be replaced and re sized
- Head gasket surfaces milled to proper RA
- MHG
Now with all these things considered im picturing all the machine work alone being well over $1000 done properly.
This is just going for a stock short block rebuild, and the costs are very high if my estimate is accurate, for a stock built bottom end.
My other option is to go through a service such as this
http://www.rpmrons.com/Toyengines1.html
Where the fully built short block is only slightly above $1000. My only concern with this route is the deck surface, it doesn't seem logical to buy this thing all assembled and have to tear it all back apart again just to get the deck surfaced to the proper RA.
What im wondering is can i take this fully assembled short block to get the deck machined to the proper RA for a MHG and have it cleaned out properly without taking it apart? At this point it doesn't seem logical to build my own engine with all the machine work that is involved, when i can just go out and buy a fully rebuilt unit.
Thanks for any suggestions.
I also must add, this build is going for a little over stock horsepower at first, im not shooting for big numbers. Im going for reliability here, i want a car that is quick around town while maintaining perfect reliability.
- Crank ground
- MHG
