MA RI supras
tsuper92
supra addict
Apr 7, 2005
1,376
mass
koreyd;1253988 said:
the mod list
440 injectors
afpr ... jtube removed dampner gone csi gone
vpc/safc ... no tuneyet
turbo from 87
egr gone and blocked off
oilcatch can
char can gone
all this was done at the same time
oh the block is fctory rebuild ... not by me but block has a welded tag
other than the fuel pump issue the is going well... if a neighbors house hadnt blown up i would be trying to tinker now but do not want dxplain my build to fire and police because of the smoke and smell
what are you running for static pressure on the afpr.440's are stock size injector's on a 7m,so maybe something else is up.i'm not familiar with the vpc/safc combo on a 7m ecu.i'm not sure how it does pulling fuel at cruise speed.i have a stock ct you can try.it has a cracked exhaust hosing,so you would need to swap your's on.
koreyd
172
fall river mass
i pulled the turbo saturday. everything looked fine no oil where it shouldnt be. my main issue right now is keeping it running.i think the c.o.r. is overheating and sticking open. but when ihave fuel pressure its set at 38 psi. so here is what happens the first time i start her she runs fine but the 2nd time there is no pressure. after that its hit or miss. its starting todrive mecrazy. gonna try wiring around the c.o.r and see how that works for me
koreyd
172
fall river mass
yes she does start and run at idle sometimes
but realized yesterday that i didn't have anymore gas in her
and ran out of daylight so i will get back there this weekend
and try to get it all sorted out
hopefully i didn't kill the pump by running out of gas
we will see
welcome 91 supra
jdm_emperor
109
MA
91supra;1255654 said:
i'm from the boston/south shore area.
i own a blue 91 supra turbo
wow looks clean, nice. my supra is down, i need a new clutch master cylinder, replacing is gonna be a bitch:1zhelp:
tsuper92
supra addict
Apr 7, 2005
1,376
mass
ah it's easy,if your a contourshanist;)
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Yup, I had to do the clutch master and slave cylinder in the fall. Not too bad but definetly a bitch being 6'1" crawling under there.
koreyd
172
fall river mass
anyone have a afpr that i can use of about an hour to see if the one i have is junk
need to try something else. i am still having problems with the fuel pressure
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Stock afpr? I've got mine kicking around somewhere, I'll look when I'm out cleaning my truck today.
jdm_emperor
109
MA
i just finished putting my master clutch cylinder in and it it turns out i need to replace the slave cylinder too:3d_frown:
any one locally have a good working slave cylinder? i need one for a 91 7mgte r154 tranny,
is there a difference between the turbo and na slave cylinder?
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
Hey guys. In southern NH here. I have that slave cylinder, emperor.
It's brand new. If you really want it, I can grab it tomorrow morning. We can meet somewhere or I can ship it. (only be about $5 to ship).
PM me.
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
koreyd;1254074 said:
well i have had my car for about 2 years now. i ran a 13.2 at ne dragway last year. finally tieing up all the loose ends
Make sure to hit up NED this summer. You will have some comparable competition. VPC/SAFC, 14psi, here.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I hope to have my car up at NEDW late this summer. Want to find a car trailer to make things easier, a Tow truck ride 100 miles home would be expensive.
