Lug nut torque
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
keep tightening til it starts spinning freely, then back off 1/4 a turn. :)
76 ft/lb, like they said.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
I work at a local garage and I never torque wheels at any less than 100 ft/lbs. It is tight enough to hold just about any wheel, yet loose enough not to over stress the studs. Yes, I do zip lug nuts on with an impact. Key word is zip them on. No more than 2-3 seconds unless it is like a huge F-350 and even then I am cautious. Just my 0.02.
bowsercake
828
Irvine, Ca
I would never go to your shop if you only use the impact gun. Precision is with the extra minute.
Use a torque wrench and set it to 76.
bowsercake
828
Irvine, Ca
I watch Just Tires and they torque with the impact, lower the car, and then use the torque wrench to finish it off. Everything but tires I do myself.
mdr40z
arkansas
If I ever let them do anything at a shop (I rarely do tho because at their last job they were asking 'do you want fries with that?'), I insist that they hand torque the lugs
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
wow....... you also know what hasn't been mentioned the fact that when you over torque with an impact and stress out the studs the next time you take them off they will snap.
i have seen it all working at discount tire, and have seen a million studs break, you know if you use an impact without a torque stick for about 3 seconds on as low as 100psi you will hit about 150 ft/lbs, the studs on our cars should never see more than about 110 MAX. the recommeded is 76 i usually torque mine to 80 ft/lbs for my little reasurance. but why would be that lazy that you cant take 30 seconds to torque and do it right.
putting on wheels and torquing them is about the easiest most common thing to do on a car, and if you are too lazy to even do that right i would not want you doing any other work on my car.
harsh?.........yes, true?.........yup my .02 cents
Syris
Need Rust Repair
Aug 24, 2005
687
Bryan, OH /Lima, OH
Thats possible but thats not an always true statement. For if you want to get really technical, how about what your impact is set too... Tire shops arent out there spending as much as they can on 600ft lb impacts. No they buy the el cheapo unless they are having the mechanics use their own. So if using the el cheapo is over torquing in 3 seconds, wow I can't imagine how mnay studs could be broke right now. If anything they are hitting just about 100 ft lbs on those
