Guys,
First I will list the modifications done to the car
BIC DDP to 3.5" Straight pipe
Apex Intake
Apex AVC-R tuned to 10-11 psi
Cooleeze 2.5" hardpipes
Innovate LC-1 with DB gauge
stock turbo, stock intercooler, stock fueling/AFM
So with the wideband installed and calibrated and the boost controller ramping up boost as quickly as possible I noticed that when starting a "pull" in 4th/5th gear from 1500/2000 rpm the car will jump into boost and be up near 10/11 psi and until about 3500 rpm I am getting A/F in the 12-12.5 range. After 3500 to redline the a/f drops down all the way to 10.3 right by the limiter (pulls to the limiter done in 2nd/3rd not enough road/lack of traffic to do 4th/5th).
I am aware that 12-12.5 is still safe but I am wondering if I should be worried about it while still being with stock ECU and timing. I am aware that the fuel pump switches to 12 V at some point (probably 3500 RPM based on A/F's) and I am wondering if I should run 12 Volts all the time to try lower A/Fs in 2000-3500 rpm range.
What is everyone's thoughts on this? Is it fine for stock fuel/stock ECU to see those A/F's under boost at lower RPM's? Should I be doing the 12 V mod to make it more rich down low? Should I bite the bullet and buy an SAFC even though I really don't want to mess with fueling, (could richen down low and lean it out up top). Right now I am unsure of what is the best thing to do and I was thinking of backing the AFM screw out to help lean the high RPM zone out but fear the effect of doing that on the low RPM A/F's.
Discusss
Apex Intake
Discusss
