Low coolant light on
hcorea
Newbie
May 10, 2009
58
Kansas
I just turned it on this morning and saw the low coolant leak light on. I put in some antifreeze about 2 weeks ago and now I checked the overflow bottle and theres nothing in there. Whats going on? Its not a blown head gasket because my engines running fine and its never overheated
92nsx
2,957
Clearwater, MN
LOL, is "engine running fine and dosent over heat" all of your trouble shooting on BHG? :3d_frown:
supraken
47
pensacola, FL
when you fill it up drive it around get it up to temp and turn it off get out of the car see if it blows out of the overflow hose, if it does, you have a BHG on the exhaust side of the head gasket, thats what happened to me:3d_frown:
jgcable
180
Milford, CT
Me too. Car ran great up until the day I tore it apart. It even ran great after the BHG really started to let go. It took almost 9 months for it to go from bad to real bad.
The progression during 9 months was:
adding coolant every few weeks
adding coolant every week
adding coolant a few times a week
temperature spiked a few times
TIME FOR REPAIR
hcorea
Newbie
May 10, 2009
58
Kansas
engine has 158k miles on it so if a headgasket blew I'd think it would've happened already and it got fixed.
I'll get the cooling system checked out after I get back from summer i guess
ft413
learner
Sep 23, 2008
90
EL
have you changed any of the 20 year old hoses on the car:naughty:. and it matters how your driving the car not how many miles are on it.
jgcable
180
Milford, CT
Not necessarily. Mine went at 105K. Car was pretty much babied its entire life. Still is. 150K is not uncommon for a BHG to go for the first time.
You need to get a leak down test performed. If you take it to a shop they should charge you around $90.00
T-MA71
Always broken down member
Mar 16, 2008
213
Nashua, NH
Mine hasn't gone yet and is well over 220K miles. Need to order a set of ARP's and should be ready to take it apart once it blows.
But yea, i would check for leaks. Coolant doesn't just dissappear...
Aug 15, 2008
75
Navan, Ontario
i have the opposite problem (kind of)... My Coolant Reservoir constantly remains full, yet the rad always ends up needing me to add more fluid? And i just replaced the radiator last week! Anyone have any ideas?
supraphoenix
broke and hating it
Mar 14, 2009
59
Colorado
Mine blew at 178K and it seemed great until then. It has nothing to do with miles. I got the radiator replaced alone with water pump and thermostat, then the headgasket. Just make sure that you check for the BHG before you replace anything on the cooling system. Cause if you do have a BHG then you'll be replacing them all over again if you don't fix it
supraphoenix
broke and hating it
Mar 14, 2009
59
Colorado
I would say check the hoses that run from one to the other. It probably isn't balancing the coolant like its supposed to.
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
bad radiator cap silverbullit. it is not venting properly.
i have a similar problem but i dont loose coolant. when i take a corner moderatly hard my light comes on... and my coolant is full in both the radiator and the bottle. i have cleaned the bottle and triple checked the connection...... time for a new bottle/sensor
Aug 15, 2008
75
Navan, Ontario
I have thought about that, however, even when the coolant goes down in the rad, the coolant light never comes on? Is this because the sensor is in the overflow tank???
fixitman04
Sep 18, 2008
787
north dakota
yes it is in the bottle.
dumbo
1,911
Albera, Too Far North
Couldn't it be a small leak in the hose from the oerflow to the rad? Allowing air to come in on cool off?
