loss of power
bis_1315m
197
charlotte north carolina
mk3_chris;1429365 said:
rusty gas tank, sry for the confusion. cleaning that tank should be #1 on your list of things to do. Even if you didn't get your pump wired in correctly the rust will kill it within 3 weeks(if you even get that long). Also be careful if you get it acid dropped like I did with mine, the acid eats the rust away so that if there is any small pin holes(that may be plugged with rust) it'll eat through leaving a bigger hole.
Alright yeah I cleaned it up today and its drying out but what kind of negative affects can come from not bypassing the pump relay and resistor if any.
thanks
Michael
Oh and believe it or not I've been running the pump for about 5months but the reason I think it might have taken the abuse is because Ive changed the fuel strainer like 3 times within those months
