Yeah I also agree. Just about everything on my stinger is controlled by the boost pressure per rpm. If my boost drops then the timing and fuel also changes. Here is a log I just made with the wastegate hooked up to the throttle body and the top port left open.
RPM............Pressure.............Ignition................TPS...............Injector ms..............ET
7053..............12.836...............18.6..................92....................18.834.............129.2
7092..............12.980...............18.2.................90.6...................18.956............96.8
7033..............12.763...............18.8.................89.1...................18.824............132.8
6900..............11.676...............19.4.................98.2...................17.544............150.8
6848..............11.240...............19.4.................97.2...................17.016............145.4
6752..............12.473...............19.2.................98.4...................18.462............122.0
6702..............13.561...............18.6.................97.2...................18.822............149.0
6655..............14.141...............18.4.................97.1...................18.976............132.8
6618..............15.374...............18.4.................95.9...................19.486............154.4
6601..............15.592...............18.4.................93.4...................19.538............123.8
6534..............17.042...............18.0.................92.8...................20.206............158.0
6467..............18.057...............17.8.................92.5...................21.562............141.8
6435..............17.840...............18.0.................92.5...................21.294............138.2
I probably didn't have the accelerator completely pressed down is the reason my tps is reading shy of 100% but I did this pull out on the road in front of my house in third gear. It's a fourty mph zone and I was going a little bit faster than that.
Could all of this be caused by my turbo? I took my turbo apart and the fins look great to me, but if it does this without the boost controller hooked up then it can't be related to the AVC-R. I'm just wondering if the turbo can't keep up with the flow.
Cade, the boost controller thinks it's holding the boost steady at 17psi, but the datalog shows differently.
Thanks again to everyone trying to help solve this issue. For those that aren't reading this, they can kiss my ...................:biglaugh:
