Loose wires!!!!!!!!!!!!!!!!!!!
empera
Authorized Vendor
Philly.
lol nah why do u ask?
I'm pretty sure something is fucked within the harness......reason why im thinking i should just start from scratch.
empera
Authorized Vendor
Philly.
ok i have spark and fuel but still nothing....i reset the timing once again....TDC on cams and Crank and then lined up the CPS....
this is what im getting...
Could my DS62 ignitor be bad?
8,898
empera;1560791 said:
so last night after leaving the gas station i was cruising when the car suddenly went super rich and eventually shut off. Tried cranking a few times but didn't do anything. I tried to reset everything by unplugging battery and trying it again and nothing.
I have spark and I can hear the pump prime, it just cranks but will not do anything else. I looked at the timing and it seemed to be right.
thanks,
-emp
The pump doesn't prime unless you have an engine run signal. Unless, you short the FP pin in the diagnsotic box. I don't know if you were refering to that or not.
This sounds like timing to me. Having a lot of fuel doesn't necessarily mean rich. Lack of burn will put fuel right out the exhaust. Jumped timing will do the same thing. Sometimes it will start but run really bad and smoke. Others will run bad until you pick up speed. Others won't start at all and will backfire.
empera
Authorized Vendor
Philly.
car doesnt really back fire......
and by prime i meant the fuel pump turns on when i turn the key into on position.
I'm really stumped right now....
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
I have herd of AEM having bad connections.
Are you using a stock ignitor?
How do you know it went rich? From wideband? Rich on a wideband means rich, Missfires show as lean due to extra oxygen.
Did you try starting fluid?
empera
Authorized Vendor
Philly.
Broken Camshaft.....
broke right after the cps gear so not only was it only opening 1 exhaust valve but there was some spark. I just installed theres BC cams....fucking hope i can have this replaced.
empera
Authorized Vendor
Philly.
will have pics soon.....def. not noticeable when i took off the valve cover....only when i spin the cam gear....i'll get it out 2moro
mkiiichip
1,434
WI
DAMN, i wonder where the rich reading came from before it died? Was the rich reading a split second thing, or over several seconds?
empera
Authorized Vendor
Philly.
couple of seconds....car didnt react at all after that so it makes sense.
I am REALLY hoping i can have this 1 cam replaced if not i fucked outta 300 or so bucks for a replacement
Nosechunks;1562892 said:
Is this new grounds? Maybe a record, or accomplishment to break something the mighty car part breaker (IJ) has not broken (At least on this car)?????????
Crazy though fo' sho.
:p
empera
Authorized Vendor
Philly.
removing them today, i didnt go anywhere near the shop yesterday...since it was mother's day.
