With-ABS and Non-ABS have different Master Cylinders. 1986-1990 and 1991-1992 with-ABS are also different.
That means there are 3 types of master cylinder: 86-92 non-ABS, 87-90 with-ABS and 91-92 with-ABS.
On 86-92 non-ABS and 87-90 with-ABS master cylinders, the front port is for the front brakes and the rear port is for the rear brakes.
On 91-92 with-ABS master cylinders, the front port is for the rear brakes and the rear port is for the front brakes. The front port (rear brakes) is also an "orifice-type" which "reduces idle stroke and improves brake pedal feel."
I know the clutch master changed from cast iron to aluminum for 1991, this may also have been the case for the brake master as well... can't remember anymore.
Jeff
