don't forget about the tensioner. if you have never changed a timing belt on a JZ engine, you will need a bench vise or a hydraulic press to push in the pin. once it's pushed in, use a small hex key to retain it.
also make sure to not push the hex key too far out; it will get in the way when you are reinstalling the tensioner.
