Longer wheel studs
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
Some OEM Toyota truck studs are a hair longer but it's a lot to spend for an exra 1/4 inch.
Search toyota wheel stud on ebay, I picked up a set and haven't had any troubles, you can get ones that are moe than an inch longer, you will have max thread then, in fact you might need open ended lug nuts if you get ones that are too long
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
I can't do that, Because I still need to fit my center Caps.
Jeff, Thanks, I'm going to get a price quote for 20 of them in that case
turbogate
Life is Boost
May 18, 2005
425
South, FL
Do you guys know the length of the stock studs by any chance for comparaison? I have some longer studs that came with my H&R spacers, but they don't specify how long they are, and I might use a different spacer after all. I want to make sure how much longer they are compared to the stock. Are studs measured from end to end? or the threaded part?
Thanks
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
my budy who own's a sweet 90 order some arp ones and when he got them there were longer then stock oem ones
not oem ones arp
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Three turns is not a safe rule of thumb.
The nut needs to screw on the stud at least the same amount as the diameter of the stud. So if you have 12mm studs, it needs to screw on 12mm, or more. If the safety inspectors at any NHRA or SCCA event are doing their job correctly, they will check that. You can't go by turns, because if you have fine threads it will go on a lot less then with coarse threads for a given number of turns.
Jeff Lange
Administrator
4,922
13
Sunnyvale, CA
jefflange.ca
Almost any pickup truck or 4Runner.
FJ40/BJ40/BJ42 Land Cruiser with front drum brakes.
FJ60/BJ60/BJ70/FJ80/FZJ80 Land Cruiser
05/91+ AE92 GT-S and SR5
92-97 Corolla (AE92, AE95, AE101, AE102)
KP61 Starlet
1987-1996 Camry
1991-1997 Previa
1984-1989 2WD YR2x Vans
1996-2000 RAV4
For JDM Fellows:
VG4x Century
AE10x Marino/Ceres
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
KP61 Starlet
1987-1996 Camry
1991-1997 Previa
1996-2000 RAV4
For JDM Fellows:
VG4x Century
AE10x Marino/Ceres
Flawless Victory. :biglaugh:
improved
Running!
Apr 4, 2005
195
California
Are the car studs listed above supposed to have an exact fit. I went to purchase wheels studs for a 97 Landcruiser amd the Knurl size was 14.17...The supra was 14.33mm. Is this difference dangerous?
Also the shoulder length of the Landcruiser was longer. I can't remember th measurement exactly, but it looked 5mm longer. Overall the bolt was 4.5mm longer.
Is this the correct bolt everyone is using?
Cheers,
Matt-
