SupraSportJack said:
MAlloy
Are you referring to the the filter? I know we don't put any restrictor on the oil lines. I suppose it would be a restrictor if the filter isn't cleaned though. The BOSS series uses all -6 feed lines and -10 return lines.
We havn't had any issues with starvation so far. I am not really sure why anyone would use the -3 or even -4 for feed lines. Simply in my mind bigger turbo needs more oil for lub and cooling.
We can make up any lines that anyone needs if you want to upgrade to larger feed lines. I will be adding a "design-it-yourself" kit so you will be able to tell us what fittings and how long and they will be custom made to your specs. The turn-around will be the same day the order is generated because we build all the lines in house
Jack
Jack:
In the past, -5 or -6 lines have been far too big for the smal shaft to4 based turbos. With that much volume, I have found that you sneak oil past the front and rear main seals.
From what I have found, -4 is the most common feed line, both by industry standard and aftermarket.
malloynx said:
i know my boss turbo came with a restrictor for the feedline. i really don't know why you are killing turbo's. how is your oil setup? id pull the line off the block and see if there is any restriction in there.
did you use any RTV to seal the flange to the block> i hope not.... that's a big no no
Mike, alot of the ball bearing turbos made by garrett (GT series) actually require a restrictor due to the fact you will blow the bearings out of the cartridge. This introduces a new problem: oil starvation due to contaminated oil.
As you stated, RTV "any thing" is a HUGE NO NO.
hottscennessey said:
okay, so I just finished pulling the turbo, there was no oil in the downpipe.. exhaust side.. or the turbo manifold.. WTF? Also, I didn't see evidence that oil had ever burned off from these places (someone told me white reidue in the past, not sure how accurate that is).
I was thinking PCV system before, but a certain retired member seems to think I should keep looking towards the PCV, I think hes right.
All turbos must have a vacuum on the return side, either by engine source or mechanical / electrical sump.
Your pvc system supplies this vacuum. You need to make sure your valve covers indeed pull vacuum off the intake track of the turbo.
Also, be sure to check that the return line isn't kinked in any way. Your return line is a teflon coated steel braided line. Check to make sure the line isn't up against the header and or melted / kinked inside and creating an obstruction.
Last, check to make sure you have a large enough air filter and that it is clean and of quality. If its dirty, small, or of poor quality it will create a vacuum on the front side of the turbo.
Report back and let us know.
P.s.
Oil burn off in the turbo is indeed white, as is some coolants.
