cuel said:
Honestly, its hard to verify what a "knock" is without atually being there, and finding it. Was really hoping the tensioner was it. Is this an auto or standard? If its an auto, maybe you might have a torque converter bolt loose, and its hitting the back of the block. Did you have the block and rods checked for out of round? Did you plastigauge the rods and mains when you put it back together? Were they all in spec? Are you sure you torqued them all correctly? Hate to say it, but you need to take your car to someone with enough experience to listen to it and point you in the right direction.
no it is not auto.
And i double checked all of my torque specifications.
also i have all brand new internals. oem .20 over pistons, stock factory rods, new crank from advanced auto parts.
Also it only knocks or pings or taps after the motor warms up after it has been running for 2 minutes. also when i rev up past 2k and when i feather the gas to shift.
i also fixed the idle pully with a brand new one. because the old on looked to have bent somehow so when i put the new one in. i thought for sure it was going to be it.
I also checked my timing like 500 times.
then i decided to check my exhaust manifold bolt to see if they were in spec and i had to tighten all of then down at least a 1/2 turn and some a full turn. but ihave not fired it up after that. Because i decided to check under the valve covers for problems. and thought that the exhaust leak would make the noise all the time and would go away after the car has warmesd up do to the gaskets expanding.
I have only checked my exhaust side and it seems to me that every thing i fine and there isn't and exessive ware or any thing damaged
also i bought a jdm motor to fix my rod knock problem when i bought the car but that motor seemed to be more far off with rod knock than mine so i proceded to rebuilt my origanal motor.
although i used the cams form the jdm motor becasue they seemed to have less ware then mine but, had slight rust or scaaring on the area of the lobes that don't push the valve. And the cams still have that ware and look to have not been touched by the retaners
Does that part touch the retainers?
Should i put in my original cams?
Or do you think that it was the exhaust leak?
