IJ.;1195717 said:Read "active"
it's not a passive system like A2A that relys on car speed.
i know but doesn't the coolant then have to cooled by the air??
IJ.;1195720 said:A well designed system has a fan on the IC Radiator hence "active"
frontierguy25;1196154 said:I live here in TX and drive my car daily in TX heat and TX traffic and I seem to do Just fine with my A2A IC. I do have a koyo rad and good clutch fan with it as well. It doesn't get hot even driving for hours. But good luck with your setup.
IJ.;1195770 said:By all means if you have a constructive arguement put it forward but if you've read and comprehended my posts I don't think you do other than weight and complexity which I already mentioned.
W2A will keep the charge temps at close to ambient in traffic the A2A DOE heatsoak like a bitch I have IC In/Out temp sensors and have logged this in the MoTeC, while the temp rise doesn't have a big effect get on/off boost a few times and management HAS to pull power to compensate (if your ecu is advanced enough that is)frontierguy25;1196154 said:I live here in TX and drive my car daily in TX heat and TX traffic and I seem to do Just fine with my A2A IC. I do have a koyo rad and good clutch fan with it as well. It doesn't get hot even driving for hours. But good luck with your setup.
sportinct26;1196222 said:what do you mean by complexity? it seems simple to me. I read that shorter plumbing reduce lag? how true is that statement? would it be notisable?
