Liquid to air intercooler. ebay brand? i got a few questions
sportinct26
105
cali
so i was looking on ebay for an intercooler and i ran into this liquid to air intercooler.
seems preaty cheap. i know IJ has this set up but i dont think his was ebay brand
PRICE IS $70 plus shipping
liquid to air INTERCOOLER
seem that its rather cheap.
anybody else used ebay liquid to air IC?
and i was looking at this. liquid to air INTERCOOLER
would it flow 450whp?
i will be using an upgraded ct26.
and from my understanding i only need a "radiator"/ heat transfer and a pump to run this setup right?
any drawbacks?
Pantaloon007
Permanent Ban
Apr 2, 2008
76
Vegas
Alot of guys use them in MR2's mainly because of the limited space and mid-engine config, not because theyre so much better. If you think about it, there's a helluva lot more to go wrong with one and you still need the water coil in the place of your current IC. The pressure drop is about the same- the air still has to fight through coils to get to the IC outlet. The first link looks like one that youd see in an MR2's engine bay.
just my $.02
sportinct26
105
cali
i would think it would be better on stop and go. ive had big IC that would heat soak badly on a 95 deg weather. and IJ i was wondering if the second would support 450whp? im looking for stealth look. IJ would ic get heat soak if it were to be mounted inside the engine bay ? or does it have to be outside like yours?
Better to keep it isolated.
The kit I have here will easily support 450 I swapped it out when I got over 500 and you're correct it's so much better than A2A for stop start.
If you want it PM me and we'll discuss a price as I'm not going to use it again.
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
i use this setup on my supra. i have the stock turbo though
its been great for me so far, and the radiator and water pump is what you will be spending more of your money.
but, i have an extra intercooler, same size youre looking at if you would like to grab it
i'll give you a better deal than on ebay if you will take it. I originally got it for a different setup i had but then i couldnt do that, so i had to buy a different one.
i guess, email me at sscrews@scu.edu
sportinct26
105
cali
email sent
dumbo
1,911
Albera, Too Far North
there called 'aftercoolers' and i would stay away if i were you.
even in school they told us there less effientied then intercoolers, except for stationary generators. when your not getting the rushing air from moving. even big heavy equipment are going to air-air intercooler. but thats IMO
You're thinking of the inbuilt W2A Heat exchangers on stationary engines that are part of the intake.
A proper W2A IC system is active cooling so doesn't suffer the heatsoak of an A2A IC in low speed situations so for the real world they're actually better just heavier and more complex.
sportinct26
105
cali
hottscennessey;1195662 said:
There is no way an A2A IC is better than a properly executed W2A IC
does it ever get to a point where the liquid gets hot? after all it is constantly passing IC to cool down the hot air and combined with hot temps outside.
and what liquid would best work for this set up? i was thinking coolant/water/water wetter?
It's active ie: Pump and Fan so it "should" be able to keep close to ambient in mid power pulls and will rise then recover in high hp pulls as long as the system has enough capacity.
I used the same coolant mix as the engine in mine Toyota Red and Distilled water 50/50.
sportinct26
105
cali
wait so the pump "pumps" faster under higher rpm?
sportinct26
105
cali
IJ.;1195677 said:
I had my pump and fan boost activated.
how did you do that? where did you connect it?
i was under the impression that this setup is basically all on its own besides the power lines.
I ran it through the MoTeC, you could do it using a simple hobbs switch on the intake and that will give you some adjustment.
There's no reason to run the pump and fan all the time as the coolant will thermosyphon through the system at light loads and keep the intake temps at near ambient at cruise depending on where the radiator is mounted.
Mine was #1 in the airstream.
sportinct26
105
cali
wait so i put it directly on the intake manifold? or could it be mounted on IC piping after the intercooler?
to double check a hobbs switch is one that is pressured control switch right? and boost adjustable? how much psi can the hobbs switch handle?
dumbo
1,911
right on, i suppose in theory that it makes sence, but you'd figure the coolant would eventually warm up but again in theory i suppose it would cool too. ne ways... i'm done
