bringing this thread back from the thread, i'm currently still building the 1991 mk3 fully rebuilt 2jz-gte, with u.s spec twins intake pipes and air gide for cyl 5 and 6 modified rmm downpipe with hks super drager exhaust, stance coilovers are up next. Got the whole car repainted engine bay door jams , trunk jams and everything it is a big work in progress, i am in the progress in making the a/c working heater, and also cruise control it is going to be a nice and fun car to drive. Not throwing a bunch of horsepower at this one making this one a lot more streetable compared to my 600 rwhp 1j. Here are
some of the specs of the Vehicle
1991 with factory sun roof
repainted to lexus glaciar frost mica (with blue pearl)
real jdm sun visor with the real SUPRA Logo
new jdm buble sidemarker
new brake master cyl reservoir
new clutch master cyl reservoir
new clutch slave cyl
new 2jz-gte oil pump
new 1jz-gte bell housing
new euro turn signals
new 1jz-gte flywheel
new oem clutch and pressure plate
new 2jz-gte water pump
new 2jz-gte 6 speed tensioner with bracket/shock and studs waiting for install
usdm twin turbo with pipings eliminated all factory vsv's and went ttc
all brand new toyota oem bearings & seals, valve stem seals
usdm cam shafts
greddy turbo timer
ngk 6097 spark plugs bk7re, probably new number now
modified sogi shorten shifter with trd shift knob
new koyo factory replacement radiator
new mk4 tt fan clutch & fan blade
new oem dipstick and brackets
new 97 tt motor mounts
all new heater & coolant hoses
new heater bypass valve
mk4 550cc injectors
waiting for install
new window trims/moldings
new winshield waiting for install
tial 50mm bov
modify mk4 rmm downpipe
mk4 tt fuel pump
fuel dampener bypass fuel line
this is all i can remember at this moment i will update the list once i get my list from work!
without further or due here are some pictures of the work in progress
---------- Post added at 12:15 AM ---------- Previous post was at 12:06 AM ----------
