lifter knocking??
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Having some lifter noise is very normal with this engines. Not sure I have heard a 7m that didn't have it. So it really depends on how bad it is which only someone that knew 7m's could tell you by hearing it them self.
May 23, 2007
251
oakdale, california
my biggest concer is making the car ok to drive to work everyday so i can get more money. cuz i am broke as HELL right now. i have like...6 bucks? seriously lol. too many expensive hobbies...
Sell the car.......
There are very few $6 parts in an A70.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
is that all i need?? how much does the part cost?
Not sure, but there's 24 valves all together, so if all the shims need a different size (I'd say you should be able to mix and match some that are out of clearance with others that are and make a couple work without having to buy more) then I'd be planning on saving some for it.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
A machinist can cut down a piece of bar stock in the same diameter as the Toyota shims to whatever thickness you will need. IIRC someone mentioned the Ford ZETEC engine that had shims in the head (suppost the be one that doesn't) would be a direct drop in for ours too.
TKA: you still procastinating over a simple job of shimming your valves? After what all you've done this should be a breeze.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
yeah i know...it just kills me that i cant do the job in one day. i gotta tear it apart, get my numbers, find out where to get these shims, and then put it back together another day..
i'll be doin it as soon as i can
