lifter knocking??
May 23, 2007
251
oakdale, california
ya, for all you guys who were participating in my last thread, i thought i had a rod knock...i guess its just lifters....any advice on this particular problem?
much obliged folks:biglaugh:
p5150
ASE and FAA A&P Certified
Central Idaho
:stickpoke this engine doesnt have lifters. Look up valve adjustment in the TSRM to solve all your problems
And I would like to see this bolt that holds the piston to the cam..... That would be a pretty interesting engine.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
johnathan1 said:
7M's don't use lifters...this engine has dual overhead cams (DOHC) and uses shims.
Looks like you don't have a very good mechanic...
7M's dont use lifters? :icon_conf
Are you sure?
Supralover87
Beauty and the Boost
May 21, 2007
84
Ohio
it's doesn't have lifters, it has shims! I have the same issue with my MKIII.
The hole that allows the valve to pump up with oil was clogged, because my oil hadn't been changed in prolly years, so the valve wasn't lifting.
