MKIIINA;1084435 said:where it is on all supras, by the diff
Not ALL supras...MK2 is bottom left side of the motor, near the J tube.
DegreE;1084428 said:I'm just going to go ahead and ask....
89 Supra N/A. Where is it?
Satan;1083779 said:I usually avoid these hot debates, but...
Filtration systems are designed for certain "ideal" conditions. That being said, I have my own doubts that this small-@$$ filter can do 10+ years, without some clogging/ (diminishing returns). Sure the interval does NOT need to be every year, but after all the $$ I've dumped into my Supras, a $20 replacement makes me FEEL better. After seeing the rust in one of the old tanks on my '90, I knew I had to replace it. I only dropped the tank after the fuel pump failed (which is when I saw why).
We all have our own peeves and ideas of what makes us feel better. If, in fact, it was designed for lifetime use, then it would NOT HAVE BEEN made into a serviceable part. Everyone's circumstances/conditions are different, so please show latitude/tolerance for each other.
I replaced my fuel pump and changing the filter was a convenient thing to do. The brown stuff that poured out of my old filter may only have been a fraction of the filtration value it had left, but for $20, it was worth the change to me (no matter what the numbers might prove).
If you're the original owner and have taken care of your baby, then you're okay. Many of the rest of us have inherited "not-so-well-kept" Supras. Changing the filter on my '91, comes out to only about $1.18 per year. I'm okay with spending that, "just to feel better." Sure I did not own it for that length of time, but I will not be changing it for another 17 years (if that), because I will maintain and KNOW what conditions the filter is subjected to from now on.
In the end, you're really only arguing about spending $20 ($5 if on sale)... I used a WIX as well and would've been even happier with only spending $5.
Guyana00;1084452 said:If I understand Satan correctly, then I agree completely. Why ponder about the state of the fuel filter, or be convinced that it will last forever when 20 years of work has been on it when you can do it.
Not just do it, but do it cheaply and fairly easily. I mean, this applies to what Satan said, for each car, you do not know the conditions the car has been driven (or sat) through.
I DO believe that these filters are 'lifetime', but at the same time I think this notion of lifetime was estimated to be 25 years. It's been nearly that, and of course can last years longer if taken care of but like I said, for how old it is, and because of unknown conditions.....just change it and have peace of mind (regarding the fuel filter at least) for another 20+ years.
My opinion doesn't apply as much to original owners who would know what the car has been through, then they may use discretion.
Bascially my theory is that if the filter is made to last a lifetime, and if lifetime = ~25 yrs. then it's time is coming up.
It's like buying a car that has oil changes every 4k and the owner tells you he changed the oil about 2.5K ago, I wouldn't wait to get to 4k to change the oil. It's a little different because oil does not wear like a fuel filter but I'm just trying to create a simpler analogy because sometime I have an idea in my mind and the words that I type do not clearly translate into the correct meaning :icon_razz.
Feel free to question my opinion, it may be flawed somewhere, or you may not understand part of it, either way point it out so I can see the flaw or so I can explain, or try to explain, properly![]()
iwannadie;1083534 said:My supra is going on 20 years old, its been in my possession for like 4 years. I have no clue what was done to it before I got it. The previous owners could have left it sitting with half a tank of gas and no gas cap on it for a year for all I know.
theWeezL;1084443 said:Not ALL supras...MK2 is bottom left side of the motor, near the J tube.![]()
figgie;1084316 said:Anyone have tested to see what the OEM filter, filters down to (80 micron etc).
Satan;1085282 said:^^Broke one off in the wife's MKIV and couldn't drill that beeyatch out (broke the easy-out in it as well). Ended up replacing the caliper. After that, no speed bleeders for me. Maybe if I was autocrossing.
jetjock;1085518 said:Just to be clear if I had to go in there for some reason even I'd change it. Kinda dumb not to. However doing it just for grins is imo almost as dumb. And that the OP's was (supposedly) bad doesn't in any way make the filter "lifetime, my ass". One sample, and not even a good one at that, doesn't mean squat...
