Well i have acceleration problems...it pulls damn hard and will take a stang anyday but acceleration is not smooth. I had a leaky EGR and just yesterday blocked it off. Still have the problem but not as bad. I have original coil packs from my '88 with 170K miles on them. I was leaning towards maybe insufficient spark causing my issue, so what is the average life expectancy of a coil pack? Are mine due for a change? Is it possible they are not giving enough spark? is there a way to check this??
EDIT: I did the resistance check which resulted in .5-.6OHMS - good
I did continuity test and all tested infinity/0 - good
Check coil pack 1 voltage: 11.7-11.8V - good
Check coil pack 2 voltage : ~11.8 - good
Check coil pack 3 voltage: 0 - not so good???? whats going on??
EDIT EDIT: please check the other thread for this since its a new topic in a sense. http://www.supramania.com/forums/showthread.php?t=56091
