License Plate in front of IC
dumbo
1,911
Albera, Too Far North
Canuckrz;1358315 said:
Personally I'd relocate it to the side of the bumper where its not going to get in the way of air flow, if you don't want to drill holes in the bumper then you could make some L brackets that likely someone else has already said and fasten them using one of the mounting points that hold on the bumper.
Leave the car pummeling to the rednecks with their chevys and fords. :stickpoke
Drive it like you stole it...but I guess it depends on your situation and needs though.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Poodles;1358146 said:
AND getting pulled over just to have them nitpick your car because of it... I run a front plate for that very reason...
well see you live in Texas, and i live in IL, i have never had a problem at all with removing front plates and i have had cops look at my car at all times. My friend runs no front plate for 3 years on his daily and he had no problem.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
My dad got two tickets in under an hour for not having a front plate on his Subaru Legacy.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
If you use that "JDM" bracket you could bolt the bottom of the plate to the bracket instead of the top and it would look like it was bolted to the bumped but wouldn't be. If would be out of the way too.
If you're into looks put a bolt and nut in the top holes so it looks like it's screwed into the bumper.
I like the hinge idea but it probably wouldn't push back a lot and when swinging forward it might flap around. If you put stop when it hits them it will put pressure on the brackets holding it to the bumped and might eventually rip it out.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Nah, its fun to rip on the honda kids... because its all true! I don't care if its foreign or domestic, fast is fast, quality is quality, crap is crap.
FWIW, I have my front tag in my window. Damn MO laws...
