There's quite a bit to address here....I'm sure the forum will time me out before I finish my response <opens notepad>. (that's my petty bitch for the day)
Ok.....
Absolutely sure, part# 22250-50010.
Bah! Calculations!
....where are they when you have two cars with identical setups yet they turn out different results?
At one point during my build/tune phase, I kept hitting FC at moderate boost levels so I backed out the bypass screw quite a bit. Turns out I had a nice slit in one of my couplings. I replaced the coupling, but never bothered to readjust the screw. The resulting bonus is that I've run 25psi w/o hitting fuel cut.
Absolutely sure. I don't trust AFR's collected after the cat, as they are on the dyno chart. That's why I posted my wideband logs along with it. In the software, you move the cursor (vertical white line) to see the values at the point falling under the white line....which makes it difficult to just take a screen-cap, as you only see 1 value. Here's the screen-cap for that run at torque peak.
If you intend to attempt running the Lex AFM with 440's and without bumping up the fuel pressure, you will need to make adjustments for closed loop, or else you will be outside of the ECU's compensation range. I think attempting this would be a bad idea and not worth the effort at all.
The less adjustments you make at a time, the easier it is to get consistent results. K.I.S.S.
What I did was (I'm omitting a little trial and error because I didn't initially K.I.S.S.), install Lex AFM, then adjust fuel pressure until my Vf signal was mostly in the middle of it's range while steady-state cruising. Only then did I move on to adjusting the S-AFC for WOT tuning. The wideband made this part easy.
Compensating for the Lex AFM via S-AFC alone would be far from easy, and would require constantly dicking w/ settings since conditions change constantly (air temp, humidity, pressure). I'd much rather match the fuel to the air in such a way as to let the ECU handle it natively, and only step in with corrections on a small corner of the map.
Whew....hopefully that all makes sense.
Ok.....
diy guy said:moorman, how sure are you that you have the correct afm?
diy guy said:because according to my calculations
Bah! Calculations!
Those percentages aren't cumulative, as the S-AFC is only adjusting the AFM signal by 18%, not the total airflow or the total fuel. Despite that, we get back to my 'calculations' comment. Perhaps the 440s I have have been rebuilt, maybe they flow more than 440cc @whateverpsithey'reratedat. If all remained equal and proper according to calculations, those who install the Lex AFM & 550's at the same time should have identical AFR's as stock....yet I've read of many (on the SOGI list back when I was researching for my 1st MkIII) running -22% on the S-AFC. 25% more air, 25% bigger injectors, yet -22% to get good WOT AFR. Once I started reading results like that is when I gave up on calcs, at least besides getting me in the ballpark.diy guy said:using 40psi as base pressure, youre getting about 12% more fuel by bumping to 50psi. the lex maf is supposed to be 25% bigger and you still trimmed fuel another 18%.
diy guy said:btw, are you sure the second is the best tune? 13:1afr at peak torque sounds on the lean side
diy guy said:about the safc, you dont have to change anything in closed loop. only make adjustments in the hi throttle map where it matters.
diy guy said:this sounds too easy, anyone want to chime in and explain why this cant be done or isnt recommended.
