BIG no-no. :nono:
Anytime you upgrade to a Lexus AFM, you need to make sure you have the approximate 15% better flowing injectors. With a Lexus AFM, you are sucking in a BUNCH of air...and with more air and same amount of fuel, you will run LEAN. If you run lean too badly for too long, don't plan on having a running motor for much longer.
Get that thing off of there unless you've got at least 550cc Injectors.
There HAVE been people that ran a Lexus AFM without bigger injectors, but they, at the least, had an AFPR, AFC and Wideband....and even at that, it's not recommended.
So..to sum it up? Get that thing off of there!!!!!
Obviously? What in the world makes it obvious? :icon_conf
