Lexus AFM vs HKS FCD
Supra_Z
7M dreamin
Feb 15, 2006
58
San Jose CA
Hey you guys i have a semi-serious question--> Which is better I notice in alot of sig's that you guys are running the Lexus AFM/with 550 injectors. But I was also wondering about the HKS FCD what are the pros and cons of both?Which is cheaper which is more tuneable and which will last longer? Thanks in advance.
Jspec7m88
1,583
Nappy City
That is one thing that people must understand...FCO is there for a reason.
LexAFM, 550's, FPR & a Walbro...a good tuning job...You'll be good to go. :)
Jspec7m88
1,583
Nappy City
b005t3d said:
what about a lex and the hks fcd?
DO NOT run a LexAFM without bigger Injectors...Vica Versa, don't get bigger injectors with no Lexus AFM or MAFT(PRO).
However, If you DO run just the Lex AFM and HKS FCD...The outcome of that would be...Most likely, NO fuel cut...because those two items in particular raise fuel cut and/or eliminate it...But once again, You need more fuel delivery if you are going to run a Lex.
MRSUPRA
838
Maryland
I run the Lex, 550's, and FCD. I have run up to 25psi easily, and 29psi accidentally. With just the Lex and 550's, I would hit fuel cut at around 19psi. Whatever you decide to do, make sure you MONITOR YOUR AIR/FUEL RATIOS.
Jspec7m88
1,583
Nappy City
:bigthumb:
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Exactly!! Just the Lex AFM/550/Walbro 255/FPR/Wideband/S-AFC/ combo limited me to 18psi and 440rwhp even tho the A/F's were pretty rich and there was plenty of fuel left it still cut out anytime i tried to go over that. If you have a fairly solid setup that is not boost spiking all the time or poping of lines then the Lex/550/FCD is a good combo for cheap. Just my two cents.
Jspec7m88
1,583
Nappy City
There has been a lot of controversy over FCD's and what they are capable of on other forums...
From everything that I know about the MKIII Supra, Running a FCD by itself is definately not the smartest thing to do. BUT, Like above posted, As long as you are allowing more Fuel and Air, there shouldn't be a problem using it because you have clearly allowed more A/F to enter your system. Get it? ;)
Supra_Z
7M dreamin
Feb 15, 2006
58
San Jose CA
Well i wanna be running at least 20 psi. i figure that'll get me to about 500hp. I want to try to run it on tracks the most i can, but be able top haul on the highways also. So how would i go about upgrading my fuel system?
Jspec7m88
1,583
Nappy City
Well...For that much boost, and to be much safer, I would go MAFT PRO...
Along with 550 Injectors, you will be able to fine tune everything to your needs. Of course, having a FPR, SAFC, etc etc is going to be key as well.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
yea i was wondering as well what do you need to get the lex/550cc's to work fpr,fuel pump. anything else? and then i need to take it to the dyno correct? please give me as much info as possable so i dont have to ask again thanks.
Jspec7m88
1,583
Nappy City
LOL ^...Well, to the best of my knowledge, once you get the Lex/550/255, then it is VERY recommended to get an FPR. I won't say it will run the greatest but there are many people on here who run that combo and don't ever bother to tune. If you get a wideband; Apexi S-AFC, GReddy Profec B...blah blah blah, the list goes on w/ all the companies, but with this, you will be able to fine tune everything...tuning is KEY when it comes to upgrading your fuel system, period. :) I'm sure someone else will chime in for a little more info...
whenmunkysfly
Jun 26, 2006
746
United States
cool thanks so i'll just buy the electronics package on suprastore at the same time i get my lex/550 and i'll buy the fuel kit they have too. lol thanks for the info.
